Creating Second Floor Below Existing Floor
shark13
Hello,
Is it possible to create a new floor "below" the existing floor I created.  I started designing a floor plan and adding several details but forgot that I wanted to create this design with two stories.  The current floor that is being worked on will become the 2nd floor and the floor I wish to add would be the 1st floor.  Is this possible?
Thanks
Do you have Build > Floor > Insert New Floor?
If not, then ...
Build a new floor above what you have.
On the first floor, select and copy the entire floor.
Go up to the second floor and Paste > Paste Hold Position.
Back to first floor to delete what is not needed.
