Covered Front Porch Help
THEVAX
I'm having a difficult time figuring out the correct wall type to use and the order of operations to build this front porch. Below is a list of elements.
1) Cantilevered framing. The upper half is continued siding from the main structure and the lower half is wrapping in 1 x 12 to look like a box beam.
2) Columns supporting the faux beam
3) Brick Piers - "L" shaped
4) Railing and decking
Image 1  is a general idea of what it should look like, I put this together with a series of individual elements. I feel like there is a more efficient way to build this.
Image 3 is an attempt using ponywalls and raising the floor to what is now the bottom of the faux beam.
I've also included a photo of the actual house, note my model has more columns.
The other component to this is that the porch ceiling is about 6" shorter than the adjacent rooms which is throwing off my roofline.
I appreciate any advice you are willing to offer.
Jason
This is a complicated design for a new user.  Too many elements and settings to try to explain, but it can be done.
Practice and experience will get you better results.
Keep working on it.
