Ghosting at exterior wall intersections
wrcolclough
Go to solution Solved by DavidJPotter,
Home Designer Pro 2022
Looking for a way to get rid of ghosting at some wall intersections.  Still image below - on screen it flickers.  Tried a number of ways to realign the corner, thinking it is off a bit, but haven't found a solution.  Thanks in advance for any help.  Cheers, Bobimage.thumb.png.a684b78ef2130be40ecfdc8bd2c87446.png
When you attach a plan file that is open in HD Pro the result is a "Zero Kb" attachment which is useless and anyone is unable to open. What you should do is to close HD Pro FIRST and then attach the plan file for uploading. That is the only workable way to share a file. Thanks for trying but please do try again.
David, Brilliant!  Thank you so much - found the problem AND solved it, plus I learnt a few extra things during the video - like those little extra breaks in the roof plane, didn't know they were even there.  Thanks again.
Cheers, Bob
