How to get roof designed with Home Designer Essentials 2014 to work in Home Designer Suite 2022?
ChiefChrisM
I have a simple roof design created in Home Designer Essentials 2014 (Build: 15.2.0.87x32) (Windows 10) (first image).
The roof appears as desired in the 2014 full overview (second image).
But when I load the plan into Home Designer Suite 2022 (Build 23.4.0.123OSX) (Mac OS 12.2.2) and rebuild the roof, it breaks the roofline (third image).
Is there a change to the plan that can still result in the desired roof in HD 2022 ?
Plan file also attached.
Thanks.
Rooftest.plan
4 minutes ago, solver said:
It looks like your roof planes were all manually edited and not done in Essentials.
I started with the plan from scratch in Essentials 2014, and it builds fine there. It just doesn't build the same way in Home Designer Suite 2022.
I don't know why, I tried to download and got the same error message.
I didn't do anything special or tricky, I just added a second floor and lowered the ceiling height.
On your plan check the walls and ceiling height for that room.
Thanks for the advice, but it still doesn't work for me in HD Suite 2022.
