Entry doors w/sidelights
Rookie65
Go to solution Solved by Kbird1,
Hi all,
What do you folks do when you want to put sidelights next to an entry door? On a full glass one I make a fixed window & adjust the frame. Yet when I ama using a door w/some detail, the best I have found is to make the unit a pocket door so it shows the slab. Yet on the floor plan you see the area where the doors slide in to eaither wall? Any suggestions will be appreciated. Thank you!
You can turn the Hinge (Opening ) Indicators off if desired, though it turns them all off , in the Display Options if desired.
From the manual:
To show/ not show opening indicator arrows in 3D
views, turn on/off the “Opening Indicators”
layer in the Layer Display Options dialog.
