Close space between two levels roof
attorianzo
Hi,
Thanks for you reply.
Fill that gap with a wall small wall is exactly what I want to make.
The problem is that the wall I create stops right below the lower roof. It doesn't reach the higher one. Moreover, I don't want it to be seen inside house.
I'm trying to make a wooden exposed beams roof.
Thank you so much for the time you spent making that video, learnt a lot from it.
I had to manually fix the same problems as yours, I wonder if that it is some kind of bug of the software. Anyway, in some way, following your suggestions, I manually fixed the roof, even if not in the elegant way.
