Outdoor ceiling issue
BACLLC
I use Home Designer Pro 2021. On Windows10.
My question is, why does my outdoor ceiling look disconnected from the roof ?
Note the picture: the white ceiling is not touching the bottom of the roof line.
I've looked thru all of the roof details as well as ceiling details but have not found the answer.
Think about how your roof is framing. You might build, and then display roof framing.
You may use the Delete Surface tool to remove surfaces to give you a view of what's going on.
There is also the Use Soffit Surface for Ceiling which might be worth reading about.
