import plant photo
azdesigner
Hi.  I live in Phoenix, and most of the plants in the library won't work in my climate.  (I checked the Pro offerings, and none of those are good either).  Is there any way I can import a photo of a specific plant I want to use?
I'm using Home Designer Architectural 2021.
Thanks!
  • 2 weeks later...
Hi azdesigner, if you still haven't found the plants you need -- yes, you can create your own.
All you need is an image of your plant with no background (Photoshop or even Windows Paint or Photos).
Hit "Terrain Configuration > Plant Tools > Create Plant Image" and browse to your image.  Then "Add to Library."
Works just like real plant - you can "Grow" it, put it in a schedule, etc.
