Roof lines after adding porch roof?
Kenster
Hi, I am using Architectural 2021 and struggling with a roof line. Everything looks as desired until I try and add the roof over the porch which results in the roof as seen in the attached photo. I have also attached the plan should anyone be able to have time to look. I can usually figure things out even if the approach is not the best but this one has me stumped. Thanks in advance. Ken
Gateway Roof Problem.zip
Just guessing, but if you are referring to the roof on the room labeled "porch":
On the front wall of the porch, if you wish to keep the lower pitch set at 3", then you need to set the "in from baseline" to 112".
Auto Rebuild Roof is turned off, so you will have to rebuild the roof for the change to happen.
6 minutes ago, Kenster said:
I attached a zip file and in it there is a folder called Roof Picture.
It's helpful to have an image (screen capture - .jpg or .png) posted to the forum and not included in an attachment showing the issue as often it will be enough to provide a suggestion, and eliminate the need to download and review a plan.
