Problem with lights
chiefarch123
I didn't see an attached plan, yet check what the materials are for the lights themselves in the item's settings. It's one of those things that started in the 2020 release where they didn't always default on, even with the setting be told to do so. When you open the materials, go to the "bulb" and make sure it's set with "lighting white" or whichever one you want to use. When it's been changed, it should then show.
