Angled exterior wall for green house
10thAveCont
I have Home Designer Pro.
Is it possible to build an exterior wall at an angle (see red arrow) I am building a winter green house and want the glass side to be angled to capture as much winter sun as possible. Below is a profile of the building.
None of the Home Designer / Chief Architect products do sloped walls.
What are you trying to do? Build a 3D model, or just develop construction drawings -- or both?
Keith gave you the typical workaround. A steep roof plane. You might also look at sloped soffits for both the structure and glass.
If you have used, or care to learn SketchUp, you could build a symbol to represent the sloped wall and import just for a visual.
You will still need a wall there to define a room.
