Rendering
TheOtherMike
So what's wrong with the export to 'Collada' DAE file?
File\Export\3D Collada model (DAE)
Using all you creative input used in HDPro exporting instead of conversion back from a DWG export?
(If  you had an abundance of time on hand you could then export form DAE Collada to SKP Sketchup.)
IMO - HDPro produces very good 'physically based' images if time is spent with available settings.
Chief Architect Premier X12 does image 'ray tracing' rendering at a higher level.
Cheers.
