Wall Cap
solver
  • 3 weeks later...
  • 1 year later...
I'm using Pro 2020. When I create solid railings and half walls in one of my plans, I get no wall cap. But if I create a new test plan and create railings and half walls there, they have wall caps! When I open the railing or half wall objects or edit defaults in the test plan I can change the material of the wall caps. But in the other plan there is no wall cap item in the materials dialog.
I suspect the reason is that the plan I'm working on was originally created in an earlier version of Pro, and I opened and saved after I upgraded to 2020. The test plan is of course created in the 2020 version.
Is there a way to make my older plan work like my new test plan with respect to wall caps? It would not be worth redrawing the whole plan to get them, but they'd be nice to have!
Thanks,
Scott
