Three Different Shed Roof Sections on H-shaped House
MorganWood
Hello!
Newbie here (and LOVING this program!).
I am working in HomeDesigner / Architect (2021) version. I have a home design that is basically an H shape. The two vertical sides are about 16 feet wide by 54 feet long. The center of the H is a 30' square.
I want to create a shed roof (3 sections) but with a different pitch in the center (higher) than the two sides. I succeeded in creating three separate "blocks" and then joining them together, and splitting the exterior walls to open the house up... but I can't figure out how to give the center section a different pitch... Even as separate structures, the program assigned the same pitch to all three (I'm using 1.5), so obviously the long sides are higher... because they rise over a further distance...
Is there a way to create something that looks like the attached image? (Am guessing I might be over my skis with this one!!!)
Thanks a bunch!
Edited by MorganWood
clarified software version
