Shower drain
Londailey
My suggestion is  - it works for me as a work-around;
And as I say - its just 'my' work around as a solution that I have used.
 firstly -  Label the room as 'open below'; this removes the default floor; the draw a CAD circle the size & where you want it;
Then insert two floor slabs that centre around the hole you want; Mine are off centre for this demo;
Add a few points or 'breaks' to enable making  a round hole, or half a round hole on each slab edge;
add your finish; add your floor waste plumbing object; ( i did not do this bit, again for clarity )
Then- take a break.
Happy hole cutting.
  • 2 weeks later...
On 11/4/2020 at 12:03 PM, Londailey said:
Using Pro: I have a shower floor but the drains from the Library don't integrate with the floor (can see the floor through the grating). The drain just sits on the floor. How to fix this?
Where did you find the drain itself? I'm using HD Pro as well but can't find the drain in the library....
  • 2 weeks later...
