Weird element appeared and I can't delete it...
srsonido
Okay, anybody want to take a crack at what this is? Weird ladder / framing kind of element appeared. I can't select it or delete it. If I can delete the whole structure (pics) this zombie thing remains. I have restarted the Plan, the Program and the whole system. This thing won't go away and it's right in the middle of my ceiling. Just when I think I'm starting to get the hang of things... uggh.
Thanks.
SR
Follow up, in case anyone finds this useful:
Ultimately I had to set the edit area, select, and copy floor 1. Then I created a new Plan and pasted the floor 1 copy into the new Plan. Zombie killed! Yay! Cue triumphant music.
That was an okay work-around for now, I was at an early stage in a simple design. But if this were to happen again later in a design, one with more stories and complexity, it might not be so straightforward to work around. For that reason I'm going to keep the zombie Plan version so if anyone has an idea how to get rid of the zombie itself we can experiment. Ultimately I would like to figure out how to remove it.
Thanks all.
SR
