Sign in to follow this
mhdjawwad
Backsplash vs Wall Texture
I can create a backsplash and assign a texture to it or have a wall and put a texture on it.
Both appear the same.
What is the difference between the two?
A wall can carry a material on its entire surface or variations by way of "Wall coverings" (see Wall Specification Dialog -Materials Tab or Wall Coverings Tab). A custom back splash can be also custom shaped to create an area of a material you choose ON a wall as a back splash or other custom objects you may wish to create.
The main mistake new users make is to NOT read the "Help - Read Users Guide" for general orientation and then obtain a good, solid first address to your software by way of the "Users Center" at the Home Designer website. , so do not waste a lot of your time GUESSING what to do but find out how to use your software properly to create products you need and want. Educate yourself and that creates your own competence and usefulness to others.
