Gable Cathedral interaction
David_Quick
55 minutes ago, David_Quick said:
I resolved it by going to the attic level and creating a wall.
The program should automatically be building a wall there. There is probably some setting that is incorrect.
I always suggest understanding the program and why it's not doing something, and especially the automatic functions that should be working.
Manually adding things, like your wall, changes how the program operates in ways you may not understand, leading to further problems.
Please post images directly -- no need to make a PDF of an image. This makes it easier for others as an image shows in the forum.
Generally, it's best to not manually drag wall top and bottom in camera views. As I suggested above, it turns off some automated behavior.
Check the box for Default Wall Top and see what happens.
