Building a rooftop deck
SignatureDB
Trying to add a deck to a (~flat) rooftop. HD wants to add posts/beams, warns that deck is built over a non-deck floor. Tried specifying as Balcony as well as deck. Can't seem to build a 'stand-alone' deck and drop iit on top of the roof.  Would appreciate suggestions for an approach to this.  Thanks.  Plan attached.
Don
HD Pro 2021 Win7 workstation
PCotter Garage2.plan
I've not looked at the plan -- posting a 3D image is helpful as often suggestions can be made without needing to download and open a plan.
If you have a structure with some sort of roof, you might try building the deck on the floor above, then lowering it. You are free to delete framing that is not needed.
