Printing Elevations to Scale
Tripyrenees
Please please please tell me you can print an Elevation to the applied scale in print setup.
I have just gone to print at 1/100 and it just prints an Image which is whatever the size you have on the screen.
There must be an option for this.
OK - Elevation you can do it but when rendered as a technical illustration you can't.
Seems daft to me as I need to print out a technical elevation with dimensions (that I have to draw on my self using CAD lines and Text).
Thanks for the video - it cleared up this one.
Ian
Why a Technical Illustration? You said technical elevation -- guessing you intended technical illustration.
The technical illustration looks more like a traditional elevation drawing than the standard elevation - I assumed it was just a different rendering and the drawing stayed the same, but it seems it converts to an image which is unusable.
I have sorted it now by exporting to another program to give the finishing touches for submission to the planning office.  Just a shame it can't all be done in Home Designer Architect.
Vector View is normally used for elevations. You can turn the color off and probably make other changes too.
