Overlapping Walls
ChiefJeet
I keep getting a situation where the cavity wall overlaps the existing wall as shown on the left side of the image. The overlap will then also be displayed on the side elevation. Strangely, it only happens on one side. I have searched on the forum for overlapping walls but could not find anything. A help on this would be appreciated.
AAPractice.plan
Make sure the wall framing is aligned. See if there is a difference between the wall you want on the right versus the left one. Or even try reading through your reference manual under walls. Don't type in things like "overlapping", just look for walls.
I spent some time working on this problem when it was first posted and did not find a solution.
Suggest sending in to support.
I tried using different wall definitions, Room Divider walls etc and none of the Home Designer capable tricks worked.
Chief has a tool that lets you edit these difficult wall intersections manually, but it's not available in HD.
