How to rotate my plan (view) in HD architect 2021
Bobbymacgee68
Hello,
I'm new to HD, just bought the Architect 2021 version. Refering to previous topics: can I rotate my plan with this version? I can't find the tools described. Neither can I rotate the objects.
By now, I imported a CSV altitude of the surroundings of my home and built a 3D terrein. And i imported an dxf of the terrain-border and the "borders" of our house and neighbours (using QGIS). In that way I have starting point as I want to model my house as well as the garden and direct surroundings. I hope this way of working fits into the software? Problem is that our house is (of course) not situated exactly not-south, though we're only lacking 1-2 degrees ;-).
thanks, Robert
Ideally, you would rotate your terrain so that the house walls are square with the screen.
I don't see how you can do this, nor do I see how to set the program up to draw walls so they will snap to an off angle.
Maybe someone experienced using Architectural will comment.
Hi - I worked on a plan design in HDPro ( not sure if you have Chief Architect or HD Architectural ) that had a couple of odd angled walls that they were non rectilinear (90degree) apart to each other - not ideal but allows a bit more design freedom I guess.
I discovered in the 'General Plan defaults' - double click on 'Select Objects' pointer....
I entered the angles I wanted to establish and worked away from there.
On the screen  image attached I added 25 and 35 degrees for example.
Also the plan (part) I worked on with odd angles.
Hope this helps you.
thanks for the replies! Correct, I have HD Architectural.
The advice I found on the web is rotating the plan. From your replies I conclude that I need HD Pro for this. Am I correct?
As I'm no pro-user, I hope to find a solution with my current license.
A tric could be rotating in QGIS, but that's not that easy too.
Robert
