Room Divider cutting off Siding - Porch/Carport
CBrosPG
I am having an issue in my 3D view with Home Designer Pro.
I am using the room divider tool to make a porch. Our superintendent prefers to have two dashed lines showing where the beam is, and 1 solid line for the slab.
In the picture attached, you can see that the siding is being cut off on one side of the porch, but not the other.
Does anyone know a way to fix this? I've used the railing tool and made it invisible in the past, but then I have to go in and add cad lines and a slab line for there to be the 3 lines we need.
Any insight or suggestions is greatly appreciated.
Thanks in advance!
Commonly Porch outer walls should be "railing walls" set to display posts or columns, with or without railing. You should be able to change line style, color and line weight of the lines of any object in the software. I think you must acknowledge that the software is pre-programmed to do what it does and acknowledging that fact one would also have to accept that it may not fit, in all ways "what your boss wants or likes".
