Auto stairwell not generating, stairs not reaching floor
ChiefJeet
I have a straight flight of stairs and 4 winders created by split landings and winders. The total number reach the floor. When I select the straight flight and then click the Auto stairwell edit tool, it says that the staircase does not reach the floor and does not create the stairwell. I thought the winders may not be connected to the staircase but on 3d, they do appear to be connected. Please advise how to create a stairwell. I tried creating it manually following the help file but then it opens the whole floor up. File attached.
FinchfieldRdW89.plan
There is no magic in a stairwell, it's just an Open Below room. Draw walls on the floor above to form a room over the stairs. Make the room type Open Below.
Thank You Eric for the video presentation. I take it that, in a made stairs, the automatic starwell will not work. Thank you for the work around.
By the way, which screen capture program do you use to create these video?
