Parapet gable ends
SomeCallMeTim
In Pro and in Premier while in a cross section camera, one can click on an existing gable wall which then displays that walls "poly line" and its corner handles which can then be used to reshape that walls shape. This can only be done when you manually pull back the Roof plane poly-line's edges so they do not overhang that walls extents. With patience, one can then shape that wall in any configuration they wish. The only limiter is your own patience and willingness to obtain what you wish.
