Mirror in closet door
jose_pinto73
Hi,
I need help in creating a closet with a mirror in the doors. As can be seen in the picture attached, I have created closet with an opening with the intention of creating placing a door with a mirror. I have look in the lybrary and I cannot find any option to add a mirror in a door.
Or you can put in a door there, make it the thickness you need, change it to a glass panel if you need stiles and rails, change the material of the glass to a mirror, adjust hardware as needed. You can set the height and width of the door to the size needed and raise it from the floor to set where the opening is.
