Curved / Sloped Exterior wall?
emnm518
im trying to draw the front part of the house, particularly the brick portion on the picture below, I wanna draw the curved/sloped exterior wall, can anyone tell me what this design is so I can do some research on it or maybe guide me on how to make it using the software, im using Home Designer 2014, thanks in advance!
The curved part is a Custom Backsplash.
Draw it against the face of the wall, make it the same thickness as the wall, then move it left or right.
Use Transform/Replicate to move it forward the thickness you just set.
Shape as required.
That should bet you started.
