hatched walls and interior definitions
Hammer7
I create wall types and keep them in master plans that I generate all of my projects from. Open the wall types dialog, copy the one you want to change, rename it and change the fill to hatches or whatever look you want them to have. Even change the color of the hatches so you know which type of wall it is. If you are doing an "as is" plan and showing existing walls, then copying the plan to a "proposed" version, change the existing walls to invisible. They keep their position and you can work around them easier.
