Unable to create a Pony Wall or see all Wall Specifications.. why?
Luai_AB
I'm using Home Designer Suite 2020 and trying to build a Pony Wall. According to this tutorial on pony walls, once I go into the Wall Specifications, I'm supposed to be able to see several tabs: General, Structure, Roof, Foundation, Wall Types, Wall Cap, Wall Covering, Rail Style, Newels/Balusters, Rails, Layer, Materials, & Label. Under "Wall Types", I should be able to click a box that says "Pony Wall" (see attached).
In reality, when I go into the Wall Specifications, all I see are 2 tabs: General & Material. So, I can't change my Wall Type to Pony (also see attached).
Can someone help?
