sloped ceiling in a bathroom
Elliot
I am trying to draw just a bathroom plan. It isn't a whole house, just a bathroom. It measures about 163x93 interior floor dims with a partition wall separating  two areas. the right wall will be 100" high and the left wall will be 118" high.  I can create a plan and set the default value for ceiling for floor 1 at either the 100 or the 118. But I am trying to make one wall shorter than the other to create the sloped ceiling.  Not working.  The only info I found on adjusting one wall height was to look at it in doll house view and drag the top handle of the wall down or up.  I tried that but that didn't create a ceiling , so  then I tried to add a custom ceiling plane and I could not get that to work.  There has to be an easier way.
thanks
