making dormer roof match existing
bob-rpm
Go to solution Solved by solver,
Just bought pro x6/2015 (20 % off promotion, thank you). I'm a newbie, but have played with demo awhile. I'm having trouble making a floating dormer over garage match the height/peak of existing roof behind.
Increasing the wall heights anymore gives error message. Attched is front view. Thanks.
  • Solution
With Pro you have several options.
Select the dormer, right click and choose Explode Dormer. You may then make changes to the individual parts -- roof planes, walls etc.
You may also build the dormer manually which is a good learning exercise.
