Mannual Truss Web
CCarpenter
First project I did in Pro. Used standard roof truss.
You can use a Custom Backsplash. Draw it against a wall, then move. If you want the wood grain correct, use multiple backsplashes -- one for each member and a material rotated to the correct angle.
I was hoping to be able to actually build it our of lumber so it would register correctly in the materials list. I was steering away from a standard roof truss because I had other pieces that made it a little less "standard" but, maybe I'll give it a try. I tried making it with rafters but, the ends pointy and I can't find a way of specifying the angle.
Thanks!
Don't think there is a way -- not even in Chief.
