Roof cutting exterior wall height
CrippleCreek
Thank you that took care of the problem. I tried all sorts of fixes none of which worked. I think the program kept the old roof baselines and kept building the roof off of them. Even deleting all the roof sections and regenerating them did not work.
Eric, Thanks again Warren
Roof Baseline Polylines must be created by the user by checking the box in the Build Roof dialog. They control how the roof builds, but as you found, are not connected to the roof.
They often cause these type of problems. I'd suggest only using them in the rare case they are truly needed.
