Custom Layer
MAndrews
Go to solution Solved by Elovia,
HD titles only have one layer , so the only workaround is to make copy's of you plan with different names  eg My House - LVoltage , My House - H.Voltage etc and then do that work in each plan and print it out as needed , you just have to keep track of changes which is the downside to this workaround but if you do it after all the design work is done right before doing construction docs it works.
Mick.
