HD Pro Download issues
RobynKS
once the file is  on your computer , use the Library >Library Import  function to find the file wherever you download it too ,select the file ,hit ok/open and HD Pro will import the new Dal tile catalog into the Library, the other method is as Eric stated above , you cannot drag and drop Library files into the HD Pro window. ,the  only other thing I can think of is that you tried importing it before it had finished downloading ?
  • 4 weeks later...
Have you download the Core Content yet ? look under the Library Menu Item , you must do this once the program is installed , after that you can also download the Bonus Libraries and Manufacturer's Libraries too if desired.
bonus and Man. libraries
http://3dlibrary.chiefarchitect.com/index.php?r=site/library&search=&x=0&y=0&x=true&soft_family_2=2&hid_soft_family_2=2&utm_source=&utm_medium=&utm_campaign=
