roof design on existing roof and new roof
flatland
I have been working on this since last week and cannot solve the roof design. Have used Chief architect pro for 4 years and always have the same problem. I  m working on an existing two story home . Basically simply adding on addition at rear of home. Using primarily gable roof plans. I have checked every wall , and structure a dozen times. There's also a sloped roof, existing, over family area. I really need help asap. I do have auto build off. I'm using pro 2019 upgrade as of two weeks ago.
carterhomerevised 6 islandfirstfloor.pdf
carterhomerevised 6 islandrevrised.pdf
From what you have written, I would guess that you have not yet made yourself learn how to use manual roof tools. There is very little you cannot do once you make yourself by trial and error (failure and success), learn manual roof tools and procedures. You learn by just doing, failing, then succeeding.
If you do not wish to do that please post a copy of your problem plan for others to look at and solve.
