Second floor with different wall heights on sides
homerIt
Hi all, I'm trying to create a plan of two floors building. I want to make a something like this as displayed on the picture.
What technique I should use to auto build roof for second floor which has different heights of side walls?
Let say left wall is 1000mm and right wall is 1700mm. Roof pitch is 40 degrees.
I'm using Home Designer Pro 2019
The roof will build off the front wall of the porch. You have set the pitch and wall height, so you will need to adjust the depth of the porch (3rd leg of the triangle) to get the wall height you want.
Move the front wall out to make the wall taller, in to make it shorter.
