Another Roof Thread
Thab0425
Just another newbie with roof layout issues. See photos. I've read numerous help topics, videos, forum threads and I just can not get it right.
Existing Roof. I'm assuming that little drop down over the garage is the culprit. Because when I sampled a L-shaped plan with out the drop down roof, i was easily able to create the gable ends and have the ridge-lines all meet.
Addition floor plan
Addition Roof.
27 minutes ago, solver said:
You want to clean up the area I've circled?
Try breaking the wall at the red line. Set the back part to Hip. You should get a roof that follows the blue line.
I'd place the break where the new wall joins the old.
Yes sir, that's the area. I did as you said and I'm on the right track. It appears I now need to look into something else. I might have inadvertently inputted the wrong info into roof pitch somewhere.
16 minutes ago, solver said:
Made the pitch on the 2 new walls 4 instead of 5.
You are the man!!! Thank you so much. perfect!! It seems you are the main provider of solutions on here, thank you for that. I'm sure we will meet again good sir. Thanks for the signature tips too.
