Gable and Attic Wall Framing not showing
ZZONNER
22 minutes ago, ZZONNER said:
the gable wall framing is not showing
Unless you are manually modifying framing, you need to auto build framing -- maybe turn on auto build so it's always up to date.
24 minutes ago, ZZONNER said:
How do I keep some material layers from showing in this view as well?
Layer Display Options
I also have two small attic wall sections I cannot get to show up.
I don't see a wall there, so there is nothing to not show up.
Go to the Attic and draw in 2 walls. See Roof Cuts Wall At Bottom.
I know, brute force is an understatement.  It's my first project with Pro, and it's been a work in process, design / build with the wife.  Should I just delete all the roofs and let them auto build or should I just start over?  I think I can generate good enough plans for permit from what I have but would like it to be better.  Using Deck Plank for Tongue and Groove ceiling has proven to be a challenge at the hips and valley, its direction jumps around.
