Installation Error 2503 Then 2502
ChiefMartha
I have Chief Architect Premier Versions 7-20 and all Home Designer current titles (Pro, Architectural, Interiors, Suite and Essentials 2019) on my PC, all work well and I have never received the error messages you have. You should be able to run Architectural and Pro on the same computer with no trouble. I am sorry you are having difficulty but I have no idea what is wrong on your computer. Tech Support will be able to assist you whatever is wrong.
You may wish to try fully uninstalling Architectural (after you deactivate the license) and then install Pro until you can talk to Tech Support.
  • 4 months later...
No one comments on whether it's Windows or MAC. I have Windows and had to run the install as Administrator to get past this problem. Sort of makes sense. Install wants to update registry. Only Admins can touch the registry. Good Luck.
