Multiple Joist Directions
ncochran
I'm sure this has been discussed before but I didn't find anything helpful. I would like to change joist directions in several locations. I have tried using the bearing line and joist direction but I can't get them to do what I want. I assume I'm not using the bearing lines properly. For example, on a wrap around porch I want the ceiling joists to change direction at the corner. Can anyone give me some tips?
I had one there. I tried all sorts of bearing line arrangements. Does each area need to be enclosed in bearing lines? Say you had 3 or more joist direction changes within the structure. I don't understand how program uses the bearing lines to break up the structure as far as the joist directions are concerned.
