Split shed
sraquet
7 minutes ago, sraquet said:
If the floor plan was a rectangle
 Roofs build over rooms, so make the floor plan a rectangle, build the roof, turn off auto rebuild roofs.
8 minutes ago, sraquet said:
and not split level this would work
Not understanding this. Your info shows a 2 floor structure, not a split level.
In any case, you may need to change ceiling heights etc temporally to get the roof built.
Sorry, you can't see the split level with the image I sent. Punch will not produce more than 3 levels. I've attached the HD image and plan for the upper floor(s). The floor of the living/dining area is 3 feet lower than the entry and bedroom/laundry/bath area.
You need to think of non-floorplan walls as Temporary walls for the purpose of guiding the roof generator to obtain the roof result you need and want, then once the roofs are in place, you turn off "Auto Rebuild Roof" command in the "Build Roof Dialog" and then remove the temporary walls and finish you design without thereafter rebuilding roofs.
