Porch hight
Chen12
Hi,
I want to use this stairs with the platform as a base for a porch (see image).
On the side there should be a door.
I created a porch with Home Designer but I can't change the height of the porch.
A slab created with Home Designer didn't let me set a door on the side.
What can I do?
Thanks.
On the side of what?
Have you changed the floor height?
Quote
Please see new attached image (orange door).
Quote
Change the floor height is not possible. See orange circles on second attached image.
For the door, draw a wall under the stairs and place a door in it.
You are asking about floor structure thickness, and not floor height. This is probably another limitation of the software. To make it thicker, add material to the finish floor -- which is currently nothing (0").
