Copy and Paste entire rooms/spaces including contents
RobinD
Possibly a silly question but is it possible to copy and paste an entire or section of a room and it's contents? Example...When viewing two plans in tile view, I would like to copy a kitchen area from one plan to the other after deleting one kitchen to provide space for the copy.
I've tried highlighting an area of a room to no avail. Also tried to copy an entire room but left click doesn't present a copy/paste option. Thought there might be a little known trick.
Signature contains Home Designer 2018.
  • 1 month later...
RobinD, did you ever have any success copying an entire room from one file to another?  I am using Home Designer Architectural 2019 and haven’t figured out how to do this yet.  Any help would be appreciated.
11 minutes ago, TominOhio said:
I should have said that I tried to use the Edit Area tool, but it didn't work.
What didn't work?
And what exactly are you trying to do?
I just tested selecting multiple objects, copy/paste into a new plan. Also using Edit Area works.
You can create an Architectural Block and copy/paste it, or even add it to your library for reuse.
