Window Awning
Mark_RK
Is it possible to create and awning over a window?  The attached drawing illustrates what I want to accomplish.  I've spent a considerable amount of time working with roof planes in an attempt to make this work.  There doesn't seem to be a way to associate a roof plane to the side of a wall.
Thanks for your help.
Mark Kapp
Scan_20180416 (3).pdf
I'm guessing you are using Pro. Draw a roof plane wherever you want, dragging it past the wall so the program knows which way is up. Then select the top edge and pull it back to the outside of the wall.
