Can't Build a second floor
ChiefUserAndyGa
I did use the help system and you tube and, as I noted, the drop down for specifying another floor would not appear. I tried your suggestion of creating a simple plan and then adding a floor but the program will not respond when I try to open or create a New Plan. I can only save the one I am in under a new name and delete all then draw a simple plan and it will not create a second floor.
I will reach out to Chief tomorrow.
Thanks for your help
After you hit Build new Floor>etc........try this ....
Minimize Suite and see if the Dialog Box (DBX) is hiding behind the Main Window , which can happen if you click the main window making it the "Focus" for Windows. You can also check the taskbar and see if there is a second Icon (which maybe Flashing it needs attention)
