Townhouse concerns
starreece
I live in a multi-family townhouse. Mine is one of the end unit (single story). The unit next me is two story. Are there any help topic in the Knowledge Base that I should read so I don't forgot something. I'm just starting to work on the roof which only slopes on three sides.
Are there any specific instruction in the help material (Knowledge Base/Videos) that address the issue of have a separate house connected to yours. My first concern is when I start working on my roof. I have read the instructions about creating a roof. I printed out KB-00127. It may not matter that there is home attached to mine, but I thought I asked. I have the Pitch/Angle/Grade/Rise&Run. My roof runs from front to back instead of side to side.
I might draw in the unit next to yours making it the correct depth front to back but just 12" or so wide.
Then your roof will build against the wall automatically. You could delete the walls after your place is complete if desired.
