wall framing elevation
chiefszaino
24 x 36 garage.
I am trying to do generate the wall framing elevations. When I do a cross section elevation of any of the exterior walls, I am also getting the framing for the opposite wall. How do I get just the framing for the one wall?
I have spent hours adjusting the display options for the camera, the plan etc every combination possible and can not get the opposite wall out of the picture.
When I do a cross section elevation of the wall from the inside, I can get the framing for just the wall that I want, however it is in reverse of what I need. I can send this reverse image to a layout, once on the layout it looks like you can do everything possible to this image except flip it to a reverse position.
Home Designer Pro 2018
build 19.3.1.8x64
