MAKE A bar top on top of island
carlosng
If you have Suite, Architectural, interiors or Essentials you can use reconfigured cabinet parts to emulate the side parts of the bar in your picture. The bar top can be made from a Shelf or soffit (cabinet tools) and also if you have HD Pro you can use a custom slab or custom countertop tools it has. Just think a little "out of the box" in terms of the tools your software has that you can use to emulate objects.
I solve this problem by mounting a base cabinet on top of another base cabinet and then configuring the top one as the bar top.  Just specify the base height of the top one to be the top height of the lower one.  Adjust the countertops to extend as you wish.
