Help!!! Exterior crown molding
wheelers
Help, I am a builder and trying to finish up a home design.  It is customary in this area to put crown molding on the exterior of our homes below the soffit where it meets the exterior sheathing (i.e.brick, siding,etc).  I can get it on the fascia, and i can manipulate a soffit and create it easily below hip roofs, sheds, etc......at this location.  My problem arises when I get to the gable.  I have tried sloped soffits, shapes, etc- no luck.... advise anyone???
You can apply a molding profile (crown mold) to a soffitt,and resize it so only the crown mold shows and the copy-paste around the outside of you home provided you have either Architectural or Home Designer Pro that is, I do not think Suite, Essentials or Interior Designer will do this, take a look.
